how hot does your s4m get? with full speed and dynamic switching (acpi)
please, post your temps.
thanks
so does anybody actually have any temperature values for a s3/s4 to compare with mine ?
About 55C when it's doing nothing other than web browsing and is running at reduced speed. That's after being powered up for over 4 hours.
i cant believe that this heat issue is still on these models. i have the s3xp and had the same problems, is there heat on the bottom right side of the unit which is almost to hot to touch, it used to leave red marks on my legs when using on my lap. mine has cooled down for months now touch wood but ive seen alot of people on here with the same issues regarding the heat of the machine, i have read reviews in a magazine called 'what laptop' which mentions the heat is a concern,
yeah, heat is def. still a problem. i read somewhere that the nvidia card in these models has a serious heat problem.
i think thats **** up. if i do NOTHING with the notebook, it runs at 50-60 degrees and if i do something the temp. walks up to 80 degrees ?! wtf..
how long will the cpu play along ? damned sony..
Intel say the Pentium M has a critical temperature rating of 100C so according to Intel 80C is an acceptable temperature for this processor.
Could get a little warm on the legs though . . . . . .
"not 'arf"
last bump..
temp infos anyone ?
last bump..
temp infos anyone ?
last bump..
temp infos anyone ?
i have read that the centrino can run up to 100 degrees which seems abit warm
i have the centrino to mine runs at 62 max out,
i think the AMD is better it is meant to run cooler
