Hi all,
I have a Vaio Pro 13 which has been working pretty much solid since I got it last week but last couple of days it has been doing something strange.
Scenario 1: Close the lid, laptop goes to sleep. Randomly and it could minutes later or hours later, it wakes up.
Scenario 2: Close the lid, come back from lunch and open the lid to find the laptop wakes but no display until power button is pressed and turned off.
Scenario 3: As per Scenario 2, but now that I know it is physically turned off after it woke itself up... I put it in the bag hours after turning it off, drive to work, hour later the laptop comes out only to find it is scorching hot because it turned itself on again!
I disabled fast startup in W8, and I don't think it's hardware related as it is not happening only when it's asleep but even why physically shutdown using the switch to turn it off (holding it down for 5-6 seconds)
Any ideas?
Solved! Go to Solution.
Hi everyone!
You may find this article useful. It shows you how to use the Command Prompt to identify exactly what last woke your Vaio: -
http://www.howtogeek.com/122954/how-to-prevent-your-computer-from-waking-up-accidentally/
It may give you some ideas to solve this problem!
Hi everyone!
The link is very helpful for me
