Hi at all !! I`m new, nice to be here. I have bought an used soni vaio , model VPCY11S1E .
the problem is that I have formatted all the 3 partitions that were ( OEM,system and primary)and put a new installation in one of this of a windows 7 home edition version from usb. Well... this version of windows is different, i think to have lost the ``vaio``part
I know that I have wrong that wasn`t the right procedure, but now how i can reset my vaio at fabricversion ?
Solved! Go to Solution.
Hi Duddu289,
welcome to Questions & Answers..:smileyhappy:
To recover from the recovery area
On models with the ASSIST button
1 Press the ASSIST button while your computer is off to launch VAIO Care Rescue.
If the display language selection window appears, select your desired language and click OK.
2 Click Start recovery wizard.
To perform the custom recovery, select Tools and click Start advanced recovery wizard.
3 Follow the on-screen instructions.
On models without the ASSIST button
1 Turn on your computer and press the F10 key several times before the VAIO logo screen disappears.
If the Edit Boot Options window is displayed, press the Enter key.
2 Select Start recovery wizard.
To locate the contact details for vaio support either click Support at the top of this page or click the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then next Select Model..
Then click Log-In
Once logged select Get In Touch.
Then Click on the Out of Warranty tab, then Phone support.
Hi Duddu289,
Then click Log-In
Hi Thalamus, thanks for answer. So with recovery disc from sony i can restor all like new?
The problem is that my vaio model doesn`t have the cd/dvd . How I could do ?
That famous DVD by sony for restore, why the don`t came with vaio too?? There a way to download somewere? maybe putting on an usb bootable ?
Let me kwno please.
Best regards.
