Hi. I have the sony-vaio laptop FZ-11M with the windows vista home premium. I have a problem with the Reports and solutions of problems which is in the control panel. Specifically, when it caused a problem for example to internet explorer, in the line of work of windows near the language it appears an econ that says it found solution. When I click to this econ it appears a window of Reports and solutions of problems that says to select a language because in my language (Greek) doesn’t appear. When I select the English language it appears the message that says it is not possible the appearance of page. This happens not only with the English language but also with others. This problem is appeared from the beginning of buying this laptop since 5-6 months ago. What can you tell me to solve it? Thanks.
