Need to get driver for DVD in VGN-NR38E after win7 upgrade
SOLVED
profile.country.en_IE.title
robbie.sony
Hi. Sorry for reposting this, but it seems like a simple question, yet i haven't had even one reply! Surely someone out there has experienced this before?? Any help please?
In addition, my dvd drive is a MATSHITA UJ870QJ.
I have upgraded my VGN-NR38E laptop to windows 7. I re-installed most of the drivers, and I installed the Event Service, Shared Libraries etc. to get my FN buttons working again.
However now I need to update the driver for my DVD writer. On the support page, there is a driver update "SuperMulti Drive Firmware AD-7560A - DS06". However, when I try to install this, it says I don't have a compatible drive! Do I need to install an earlier driver first? If so, where can I get it?
Message was edited by: robbie.sony
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
The drivers for your disc drive are supplied as part of Microsoft Windows and will be provided automatically by Windows 7.
You do not have a AD-7560A disc drive so it is not unsurprising that the firmware update will not install.  Your model can be fitted with a few different drives.
There is no update for your Matshita drive so you do not need to do anything.
:thinking:
2 REPLIES 2
Blencogo
:thinking:
robbie.sony
Thanks for the reply! I think I know what happened.... A couple of years ago I was advised to use a AD-7560A update by sony support for an issue i was having. As far as I remember, the update worked, but it didn't fix the problem - so I sent the latop to them to get repaired. I guess they replaced the drive with the MASHITA one - and i'm only noticing it on the upgrade.
Thanks again!
