Hi people,
\i have a VPCEB1Z0E laptop and can not solve an issue.
The laptop has a ATI Mobility Radeon HD 5470 graphic card.
I installed CoD 4 and if I play using max resolution 1920x1080 the graphic is not smooth. When I change to a lower resolution the size of the screen changes and it is terrible to play.
Does anyone knows how to use a lower resolution but in full screen?
Thanks
no solution by now
Hi there
Some forums say that it can't be done, but a couple suggest if you go
into the settings files within the game files you may be able to change
the fullscreen value to 'true' whilst it is set at a particular resolution.
I wouldn't change any files, but if you do then create a system restore point first.
