Hello.. This seems simple task but Uninstall does not uninstall all of it. Somehow the DEFAULT picture folder is not the correct one so I want to change it,, But you can only change sub folder.. I did an uninstall and cleaned to registry but on re-installing there is NO option to select the DEFAULT as it has remembered the original. I asked Sony Support
.. see email..
I need to be able to completely remove PMB because the DEFAULT folder is the wrong one. I have tried to Uninstall and then delete the PMB folder but after a reinstallation there is no option to select a DEFAULT folder as it still remembers the old one. The version I am using and prefer is PMB 2.0.05.13150 which I got with my Sony Camera
The reply is..
Thank you for your recent e-mail received on 06/01/2011 09.31 AM.
I am pleased to learn that you are the owner of a Sony product. However, I am sorry to learn of the difficulties that you are experiencing.
I recommend performing a system restore on your computer and attempting to un-install the program again, which may resolve the issue. Please ensure that you read any on screen prompts that appear whilst carrying out a system restore.
I don't want to do a restore as I will also lose other programs....
There must be a way of starting from a scratch install where you can select the DEFAULT folder
Any help would be appreciated
Oh the OS is XP
Thanks
John
