My GRT 816S laptop shuts down suddenly while I'm using it, plus it's extremely hot. and it's nine months old only.
I've just set the screen luminosity to a lower value and it seems to shut down a bit less.
also I should note : it seems to run slightly slower than normal actually.
What do you mean by "extremely hot" ? Laptops generate a lot of heat in a relatively small space and so the air coming out (usually underneath) can make the surface that they sit on quite hot.
If the machine is shutting down it could be an overheating problem (heat sink, blocked vents, slow fan) or it could be a virus (Sasser?)
There is software you can get to see the temperature at which your CPU is running at but I can't remember the links - perhaps someone else could be of more help?
you can barely touch the backside of the computer. maybe it's normal but you wouldn't put it on your legs for instance.
my antivirus is updated as often as possible (several times a week), I run a complete system check each week, plus I don't run any executable files from a suspect origin, and I don't use any security weak applications such as IE or Outlook (well that's not completely true : I use windows XP, but note that I'm behind a very paranoid firewall) .
would love to know which software could check CPU heat plus CPU speed, so I could give consistent data.
Thanks for the tips.
As I'm a bit of a paranoid, I checked at microsoft's site if I was infected with a sasser worm, so I can confirm I'm not.
Another poor soul with a laptop with poor cooling.
Give the fans a clean out or contact VAIO-Link if you're within the warranty period.
I'm in the warranty period but I need the computer to work ! so sending it to vaiolink is not an option except if they give me back the money I'll lose 😕
Is it possible to clean the fans without braking the warranty ?
If so is there any tutorial about how to do it properly (never opened a laptop before) ?
thanks for you answers kee lo.
I continue this thread since I've tested the cpu temperature utility suggested by kee lo and robpaxton mobilemeter
the temperature reaches 92°C.
I just bough an antec notebook cooler, but it seems useless, since the temperature is the same with or without it. So I'm forced to work at night when ambiant temperature is cooler... thanks sony 😞
I mobilemeter[/url]
I agree Gunter.
