DVD-R Vaio PCV-V1/G - newbie!
DavidH5
Bezoeker
Hi all - I'm trying to use Sony Vaio PCV-V1/G to burn DVD-R for playback on Sony DVD player DVP-NC615 (multi-disc). I have created video footage from DV camcorder via Sony's DVD Gate Plus (easy!), then burned one .avi file onto a Sony DVD-R 1x to 4x disc as a test. The Sony DVD player says it cannot play disc. My instruction books suggests DVD-R is OK (though it says some DVD-R cannot be played back due to disc quality or the characteristics of the recording device ...) On playback through Windows media player on the PC all is OK (though sound is very poor quality). Playback through Quicktime does not work at all (just a few seconds then it stutters and I have to "end program". I really wanted to be able to transfer DV video footage onto DVD-R. Please do you have tips for a novice using the equipment I describe. Many thanks for your help,
David
16 ANTWOORDEN 16
reaper
Bezoeker
no you dont need to use premiere at all if you have nero thats the whole point in having it
right if you are going to be doing this often with your own footage then i advise that you just use premiere and click to dvd making sure that you are using uncompressed mpeg2 in click to dvd
but if you are using files from the net downloaded ect ect
then its good to use nero
nero vision and express with transcode any avi file to dvd in the burn process divx xvid ect ect
it doesnt have to be mpeg with nero vision or express it just has to be an avi file
note that the process of transcoding the file can take up to four hours (if the project being burnt is hour and a half )
for this i advise you get the vision package this will allow you to make a dvd title screen in seconds burn your avi file to disk while transcoding it,
hope you understand a little more about dvd file's (mpeg2)
these by the way can be burnt to disk using nero in about 10min
or vob or iso ect ect
regards ben
DavidH5
Bezoeker
thanks ben - that gives me what i need to know
DavidH5
Bezoeker
before I sign off another quick question: when I capture my video footage it splits the footage into individual files. If i convert these avi files to MPEG2 then burn DVD-R will DVD player play clips one after other or do I have to knit files together at some stage?? I do appreciate your help!
kee-lo_
You have to make chapters for it to work like that.
reaper
Bezoeker
it depends how you decide to do it
if you edited it with premiere then no it wouldnt happen like that because you would have edited all together as a whole
but with nero vision it will play like that unless you merge the files together
this will turn it into one long stream
look as its yur footage the best thing to do no doubt about it
is to use your premiere, edit the footage export mpeg 2 then either use click to dvd or nero the choice is yours,
regards ben
DavidH5
Bezoeker
Easy! Burned a simple DVD last night, and looks great. From looking further at Click to DVD it looks like I can link up the camcorder to the I-Link on the Vaio and the Click to DVD will convert that with chapters straight to DVD. Menu on DVD will then let me Play All or select the clip / chapter I need. Very cool, and that way no need for Premiere or Nero (unless I decide to edit). Thanks for help guys. David
kee-lo_
No problem.
Now you have started you can now have a more in-depth play and learn new video techniques.
