What cable is best to connect to tv to use as monitor. Tv input is hdmi but what output port on pc should be used?
Solved! Go to Solution.
Hi aflemi,
welcome to Questions & Answers..:smileyhappy:
According to the specifications your VGN-N38Z does not have a HDMI output..
Does your TV have a VGA port if so you could try using that port to connect up your Vaio..
Or
You could try using a VGA to HDMI Convertor or something similar..
Hi aflemi,
Or
Txvm, tv has vga port so a straight vga cable should work ??
You're welcome, post back if you have any problems and we'll try to assist further..
