I have a vaio laptop running vista. I cannot get the built-in camera to run with Sype. Does anybody know how to get it to work?
Hi viks and welcome to the forum.
Are you using Skype 3.2.0.145? If not then upgrade...
Hi Rich,
I was running v2.5 that came installed with the machine. I have since downloaded the latest version but the problem persists. The puzzling thing is that it has worked a few times. How do you explain that. I suspected that the problem could be due to the second account holder on the laptop having Skype permanently on even when not looged-in, causing device sharing problems. I'm not sure if this is possible but I am despearte! But even after shutting down Skype for the second user, the problem remains.
Hi viks,
This is strange! I had the same problem with Skype v 2.5 but the upgrade to 3.2.0.145 solved the problem immediately. Does the camera work with Messenger and Vaio Camera capture Utility?
Hi viks,
What Vaio do you currently have..?
Have you checked and installed the updates for your Vaio ..?
I have the AR31s. I have downloaded the latest camera capture utility and it doesn't work either.
Hi viks,
1. Install Microsoft Hotfix KB931812 from here: -
MicrosoftVista-KB931812-v2-x86
2. Have you installed Vaio Camera Capture Utility Version : 2.2.01.04100 from HERE - read the instructions carefully, you need to run the downloaded .exe file TWICE.
Tried both but still no luck. This is really frustrating...
