First i had the bsod !! then i tryed so many things
and came to a point were i tryed to reboot the whole
system and when i start windows it trys to
install the system but it says to restart the
installation by restarting the computer
can anyone help me ????
Solved! Go to Solution.
thank u for all the help
but is there any way to fix the sata ?
Check if the hard drive is visible in the BIOS. Try to start the Vaio normally and when you see the first Vaio logo, tap F2 repeatedly. Is a hard drive listed?
If the BIOS sees the hard drive then you can try reinstalling the SATA driver using a repair disc.
If the BIOS says HDD = None then you need a repair.
ya one of them has a none ...........
i loked on the link you sent and iam from england and i cant seee a contact number ?
Did you enter your Vaio's Serial Number then go to 'Get in Touch'?
ya i also sent a email.. and they have not replies yet ?
is there any other way of contacting them >?
