First i had the bsod !! then i tryed so many things
and came to a point were i tryed to reboot the whole
system and when i start windows it trys to
install the system but it says to restart the
installation by restarting the computer
can anyone help me ????
Solved! Go to Solution.
What country are you in?
Sony give a minimum of 12 months Warranty free. This should cover you if the hard drive or motherboard fails. You do not need to pay additional insurance.
Go Here: -
http://support.vaio.sony.eu/computing/vaio/index.aspx?m=0&l=en_GB
and enter your serial number to get contact details for Vaio Support. They should be able to help you to get your Vaio working again.
What error message did you get on the BSOD?
Did you make a set of Recovery DVDs?
How did you try to 'reboot the whole system'?
What model Vaio do you have?
the model is
vpcec20e
the BSOD said something about the DRIVER_IRQL then i cant rememberthe rest, bit it ended with _EQUAL
this following things might help to
stop : 0x70860002
and i also got one later it was 0x000000D1
iastor.sys-adress FFFFF880013175B3 base at FFFFF880012EA000, date stamp
then i tryed to reboot the system i read on the hadbooklet that came with the laptop
by pressing the assist button for a few seconds then i went into Restore complete system
then when it started up it said windows is runing for the first tiem then the error came saying
that i had to restart to ...install windows ?
i have made a recover disc but it doesnt seem to work i chose the cd then it takes me to ...system recovery opions and it gives me some options but there r not helpful with me problem...
then i restart the computer and nothing has changed >?
thanks for reading my problem i hope you can help cuz i cant do any work on this computer iam using
the model is
vpcec20e
stop : 0x70860002
plese help
Hi lalbpun,
iastor.sys is the SATA Hard Drive Controller so I am beginning to think this may be a hard drive fault.
Your model type is not valid - do you have a VPCEC2S0E? If so it is probably still within warranty and you should contact Vaio Support and tell them you have tried to recover the system and now you do not have an Operating System. Tell them the Recovery Discs do not work. They will probably change the hard drive and also check the motherboard while they have it in the workshops.
thank you .but i bought this laptop abou 6 months ago and i stped paying the insurense will they still help me ?
or is there any way you know to fix the driver ?
Go Here: -
thank you ........:smileyhappy:
