- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
got this tv today and the only problem i have with it is the sound. Sounds realy distorted, thinking of getting a home cinema system or a soundbar, any suggestions ? Never used either before, wanting to use it with SkyHD if thats possible.
Thanks for any help
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Sound is always the problem with the new style 'thin' TVs. There is only so much room to fit speakers. If you are in the market for a blu-ray player, definately have a look at the all in one Home Cinema Systems : HERE. If not, have a look through the available soundbars : HERE.
Its a bit hard to make a suggestion, as I am unsure on your requirements and budget constraints.
And yes, they should work fine with SkyHD - All you do is set the TV to output audio externally.
Cheers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Cheers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks for the reply, i am on a tight budget. Max probably £150
i saw the HT-CT60 for around this price so might go for that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I ordered the Sony 2.1 Channel HT-CT60
not the best but the reviews are pretty good, and i found it at £94. Should improve things
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Brilliant. Should improve things quite a bit.
Let us know how you get on anyhow.
