Help!I need a sky remote code for my Bravia KDL32WD756 model tv
Why not try the other way around? The TV can control other devices using the Bravia Sync function. Check the manual (page 25).
Sorry I don’t see how this relates to sky codes
you don't need a code if you have a HDMI connection. You can use (Control for HDMI, AKA Bravia Sync) to control the Sky box with the TV remote
Sorry, I don’t want to control my sky box.I just want to to get sky on my tv with the sky remote.
It's the same thing you'd do if you want to control the TV with the Sky remote: Use Control for HDMI on the box.
If this doesn't answer the question, I'm not sure I understand what you want to do exactly. If you don't care about anything but getting Sky on the TV, select the correct input and it should automatically start on it when it comes out of Standby.
