Not sure how to input Audio in when using VGA input
SOLVED
Reubenatour
How do iput audio into my Sony Bravia 40BX40 ?
Thanks
Tags (5)
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.hr_HR.title
DamacizSi
Audio Jack 3.5mm.... it is next to VGA in TV and other end to audio in of PC
4 REPLIES 4
DamacizSi
Cyrax.NET
can someone confirm for 100% if the 3.5mm audio jack can act as audio in from a laptop while in pc input mode?  or is it just audio out to be used with headphones?
basically as the bravia's mpeg 4 resolution/container support is so poor, i'm thinking of just playing all from my laptop.  now i know i can use the vga cable for picture but how do i pass audio from the laptop to the tv's speakers?
thanks for any replies
edit: i have a bravia KDL-40EX403
Message was edited by: Cyrax.NET
Bravia55HX
cyrax.NET,
same as the above answer.
Cyrax.NET
oops original answer is spot on.  i don't know why but i never noticed the 'audio in for pc' 3.5mm jack next to the vga cable and i was plugging it into the headphone jack...duh...
i think i'll start playing all my mpeg4 through the laptop just to stop the hassle of codec/resolution problems playing off the usb.
thanks
