MyBookLive - KDL-48W585B
Mickm8
I am having trouble getting the contents up on screen, all I get is a message 'Could not receive the content list' every time I select 'MyBookLive'. I can get the DivX Media Server working from my PC, not great admittedly, as the contents are not listed by folders etc. and just doesn't feel right.
Any advice or guidance would be greatly appreciated.
4 REPLIES 4
Anonymous
Not applicable
Hi there
I believe you will need to enable Twonky on the WD MyBookLive as this would enable a DLNA server, of which is needed in order for the TV to 'see' the MyBook.  More information, see:
http://community.wd.com/t5/My-Book-Live/My-Book-Live-and-quot-DLNA-quot/td-p/461062
Cheers
Mickm8
Thank you for your reply, however, the TV has a generic media player and can see MyBookLive and as far as I am aware WD has moved from Twonky to their own DLNA Server, unless you mean to replace that and use Twonky?
Cheers
Anonymous
Not applicable
Hi there
Sorry for the delay in responding.  Unfortunately I dont have any experiece with WD MyBook's.  However my best guess is a setting within the MyBookLive that needs to be enabled or shared?
A PC will pick it up, becuse a the PC doenst need to see DLNA servers, just fileshares or even IP address, but for a TV to 'see' NAS drives etc, they must be broadcasting via a DLNA server.  My advice is to look at all the settings, and maybe browse the WD forums.
Cheers
Mickm8
Thank you I shall try there.
