MBD-MRX1
SOLVED
Edwin52
New
MBD-MRX1
I have a WEGA TV, sorry I don't know model number.
We have a connection box MBD-MRX1, I would like to connect a SKY mini box via an HDMI lead. Can I buy a lead to attach to SMART connector or the PC connector on the front?
Any help much appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
Hi Edwin,
Wow, this is a classic!
I don't think a simple lead will work. But it should work if you convert the HDMI signal into an analogue signal and then feed it through a Scart input. You can find the corresponding converters in stores.
Cheers
Peter
2 REPLIES 2
Hi Edwin,
Cheers
Peter
Edwin52
New
Thank you Peter, i’ve Bought an HDMI to SCART converter on Amazon. Working now, thanks.
