KDL-40E4000 (maybe entered color system searching mode) showing different colors on the display and not responding to ANY command EXCEPT Power On/Off .
Is there any combination to just manually RESET the TV or something?
Or a hidden menu combination which can help me with this out?
Solved! Go to Solution.
Hi Karen,
Looks like that your TV need to be checked by Sony technician , i would advise you to call authorized Sony service center.
regarding RESET,
1- Unplug TV from the main power supply for 30 seconds.
2- While keep pressing the central UP key on the remote control (10 sec minimum) , press the power button on the TV panel .
Regards
Hi Karen,
regarding RESET,
Regards
