KDL-32EX402 dynamic contrast, how to disable?
profile.country.uk_UA.title
80505078030
I'm using my KDL-32EX402 as a monitor for PC. any time I open a brighter or darker window the contrast of the background image changes. Looks like it's some kind of dynamic contrast adjustment. But I didn't find any in the settings menu. I've disabled all of "enhancer" features in settings menus, but this one keeps working. Is there a way to disable this feature, because I don't need it and it makes the use even worse in my case? Is there any kind of "secret" menu to unlock in this model for more settings?
4 REPLIES 4
profile.country.hr_HR.title
DamacizSi
Hi there,
Try so
manu-settings-picture-advanced contrast enchencer-of or low
http://pdf.crse.com/manuals/ADNX100131.pdf
page 55/83
Set graphic in PC settings if You like.
Regards
Damac
:slight_smile:
80505078030
yep, got all of these turned off from the beginning. even more, there's no difference between low and high.
I've shot a video for better understanding; here:
http://youtu.be/UEgAZImg1yc
look at the desktop background image. the wall behind the car and a bit to the right from the wheel. it changes color tone when pure white part appears and disappears. it may look like camera changes auto-exposition but it looks the same when look with an eye. all of the enhancer functions at the TV and PCs video driver are turned off.
connected with DVI cable via HDMI-converter plug. in process of buying normal HDMI cable.
DamacizSi
Yee,
Right. So long You use vga-hdmi adapter, conect it to hdmi 3 on TV. When You have HDMI cable new, tell as again about it.
Regards
Damac
:slight_smile:
80505078030
connected it via HDMI-HDMI cable, but nothing changes. the effect still present.
