Hi
The red light in my KDL - 32 EX 500 Sony flashes 7 times after sometime.
Do you have any syggestion
Thank you
Yiannis
Solved! Go to Solution.
Hi Yiannis,
welcome to Questions & Answers..
If the stanby light is flashing red then this indicates that the TV's self diagnosis mode has been activated, I suggest you contact your local authorised Sony service centre and inform the them of the sequence that the Standby light flashes. Use the following link to find your nearest: Authorised Sony service centre
yes its a fault code and will require a service technician to look at it im afraid.
Hi Yiannis,
said that already!!
