KDL - 32EX 500 red light flashes 7 times
SOLVED
profile.country.el_GR.title
Yiannis
Hi
The red light in my KDL - 32 EX 500 Sony flashes 7 times after sometime.
Do you have  any syggestion
Thank you
Yiannis
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi Yiannis,
welcome to Questions & Answers..
If the stanby light is flashing red then this indicates that the TV's self  diagnosis mode has been activated, I suggest you contact your local  authorised Sony service centre and inform the them of the sequence that  the Standby light flashes. Use the following link to find your  nearest: Authorised Sony service centre
3 REPLIES 3
Bravia55HX
yes its a fault code and will require a service technician to look at it im afraid.
Thalamus.
Champion
Hi Yiannis,
Bravia55HX
said that already!!
