Issue connecting 40NX710 to WIFI Internet?
profile.country.da_DK.title
happyJsat
Hi Fellow Sony Owners,
Just bought my NX710 TV, primarily because of integrated WIFI and DLNA.
However I cannot get my TV to logon to my WIFI. Here's what is says (translated from Danish):
First I go to Preferences -> Network -> Setup -> Wireless setup -> Scan.
Then I choose my network and type in the WPA code.
In "Configuration of IP and Proxy" I choose "Auto" (that's also how I do on my PC and Mac and they both connect).
I see the status page, which looks good. Next page I press "Save and connect to network".
Then the TV tries to connect (the "please wait" mode).
The results then are:
Wireless Unit: OK
Local Acces: Failure
Internetacces: Failure
What am I doing wrong???
Message was edited by: happyJsat
3 REPLIES 3
Catmambo
Contributor
Couple of things to try.
  • DOes it work if you disable your WPA key and then connect?
  • Its case sensitive so make sure you are using CAPs where appropiate.
  • Have you run the firmware update also?
Thanks
jesranmad
Hi happyJsat
Had exactly the same problem with my NX710 untill i remembered that i'm using MAC filtering on my network. Find the MAC of your TV and insert it in the Routers "allowed list".
Hope this helps...
profile.country.ro_RO.title
tuadria68
Hi jesranmad
How can i find the MAC address of the TV wirelles adapter TV?
I have a 40NX720 model; for ethernet card it's working fine because the MAC it's displayed in the menu, but for wireless card, i don't know where to find it!
Thanks,
Adrian
