I wish to connect my wii to a 32cx523
SOLVED
andrewcherryfrance
I read the comment about connecting through a scart lead but that is occupied by my sky connection is there any other way?
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
A quick look in your iManual shows this for a Composite Connection: -
I confess it is a trifle odd that the yellow plug needs to go into a green socket!!
You can open the Manual on screen using this link: -
http://pdf.crse.com/manuals/iManuals/eng/CX52x_o32/nt_vcrdvd_europe_hx700_ex500_ex300_cx500.html
8 REPLIES 8
Bravia55HX
have you tried the composite connections? (red/white/yellow), failing that you could always get a scart splitter as you can only use one or the other at any time anyway.
andrewcherryfrance
not yet, i cannot see a hole coloured white, i guess they are the top 3 of the five holes but 2 look red and i yellow, starting with the top hole i see red, then yellow, so i hope the third down is for the white lead. i am looking for confirmation before i try.
thanks
andrew
Bravia55HX
cannot advise further as info given was from sony specs (no pictures), you will have to hold out for further advice.
andrewcherryfrance
thanks for your thoughts
Blencogo
andrewcherryfrance
thank you to everyone for a correct answer, the manual provided in black and white is pretty useless, i'll try the imanual before i ask another question
firionicable
This is funny. I remember myself plugging in the yellow plug to the red port thinking that it should be next to the white one. Thanks for sharing this picture.
Bravia55HX
well i did say the composite connection, trust  Sony to change the colour config.
