Connection to Lovefilm on KDL-22EX32 problem
SOLVED
lez4u2
Can't do this as don't have the menu for activate enhanced features
Can I presume this set doesn't connect to this service?
1 ACCEPTED SOLUTION
Accepted Solutions
Catmambo
Contributor
Ah ok - the code generated is time sensitive, so ideally you need the internet.sony.tv/lovefilm page open on your computer and then generate a code from the lovefilm Tv app which you can then type into the website at the same time as the code is displayed on the screen.
Can you try again doing it as this should work fairly easily. Its not the most elegant of security solutions unfortunately, but you only have to do it once thankfully.
Thanks
5 REPLIES 5
Catmambo
Contributor
Hi
Yes this set does connect to Lovefilm, iPlayer etc. If you have already connected the TV to the web, then browse to the Internet Video menu and  you should see all the services listed there..
This video should help too
http://www.youtube.com/watch?v=X1HGy1SvI7E
Thanks
lez4u2
Hi
I've no problem with iplayer etc; the problem is with the internet.sony.tv/lovefilm site. They ask for a registration code. The code generated by the lovefilm interface isn't accepted and the instructions say to go to network settings in the home menu and scroll to activate enhanced features. I don't appear to have this in my menu, so am at somewhat of a loss!
Any help gratefully received
Catmambo
Contributor
Thanks
lez4u2
Thank you - it's working fine
KDL-CX520
Thanks Catmambo for explanation about this point , long time i was asking myself why the TV generate new code everytime i open the page for enhanced internet feature :thinking: , now i find the answer :slight_smile:
