BRAVIA KDL-32EX523 - power led blinking 8 tmes per sequence of blinking - what is goin on?
Solved! Go to Solution.
it appears you have a fault code stored in the tv' and will require a Sony service tech to look at it.
Hi again,
have you done anything about your problem yet?,
i can tell you its down to an Audio fault so with any luck a repair should not be expensive.
