40 EX503 initial set up
SOLVED
Valmyre
Hi all..
I recently purchased the 40ex503, and when i went through the initial set up i chose NTSC instead of PAL,, can anyone please advise how i can change it to PAL?.
Message was edited by: Valmyre
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
After you did the solution above were you able to auto-tune in all available channels on your TV..:smileyconfused:
If not try this..
Go to the Home menu..
Then browse to Settings..
Followed by System Settings..
In the System settings menu click on General Set-up, followed by Factory Settings..
5 REPLIES 5
Thalamus.
Champion
Hi Valmyre,
welcome to Questions & Answers..
Try this..
In the System settings menu click on Auto Start-up..
Valmyre
hi Thalamus.. thanks for your quick reply :slight_smile: and for the welcome...
I did try the auto startup but it didnt give me the option to choose ntsc or pal...
Thalamus.
Champion
If not try this..
Valmyre
Yes after i did the auto setup i  was able to auto-tune the channels , but the option for choosing PAl was not there..
If i use the factory settings will it mess other things up?
Thalamus.
Champion
If your Bravia is working ok & you are able to view the TV channels via an aerial then your TV is set up correctly..:smileywink:
Have fun & enjoy your new Bravia..:smileyhappy:
