w995 offline maps!!!
daaceking
Bezoeker
Hello,
On the support page for w995, it says to download wayfinder maploader, which basically allows offline maps. What i want to know is that, does the phone need internet connection even if it is pre-loaded maps?
thanks
Dr_Chris
Kampioen
Well, you still get 3 months of Wayfinder free and also Google maps, if you don't mind written rather than voice directions.
7 ANTWOORDEN 7
Sam
Legende
Legende
Yes it would as the aGPS requires the ability to triangulate via Cell Towers and as such would need the internet enable to assist in this function.
Dr_Chris
Kampioen
Main menu--Location services--Settings--Assisted start--(select)-Never:  This will disable A-GPS, but you can still use GPS to fix your position, although it will take longer.
daaceking
Bezoeker
i just found out that wayfinder is a trial version. couldn't the w995 atleast get a full free version. gps is just a wasted feature.
Dr_Chris
Kampioen
daaceking
Bezoeker
i would rather use ovi maps on my 5230. the thing is that gps takes ages for connection then messes up directions, so i'd rather get old fashioned map. Slightly_smiling_Face
Dr_Chris
Kampioen
Fair enough.
Niet van toepassing
If wayfinder doesn't work for you, you could give GpsMid ( http://gpsmid.sourceforge.net ) a try.
It is also an offline map application, including voice based turn-by-turn instructions for car, pedestrian and bicyce routing and it is completely free.
It's map data comes from OpenStreetMap ( http://www.openstreetmap.org )
