Sony HT-SF150 Bluetooth volume low
Huhuexist
New
I recently purchased this soundbar for TV and music but when I connect through Bluetooth the music volume really doesn't feel like 120w the volume seems lower than expected is their a reason for this or something I'm doing wrong please thanks
Tags (1)
4 REPLIES 4
Pentium_Gladio
Specialist
Do you connect it to the TV using Bluetooth or to a phone or tablet? It is normal for the sound to be lower during Bluetooth connection compared to a cable. Is the TV a Sony TV?
Regards,
Gladio
profile.country.ES.title
HAL9000z
How are the devices connected? Optical, minijack, HDMI...?
However, it's a soundbar without subwoofer, you cannot get a super powerful sound. And it depends of the source too... Have you tried with different inputs or videos (YouTube, Netflix...)?
Ollsbols
I have the same sound bar. I connect via Bluetooth from my Xperia 5 using Plexamp. The volume is fine and goes pretty loud but wireless will often struggle to provide enough oomph to drive the speakers to their max in my experience.  Use a wired connection and you should notice the difference. I will have a play about with min setup later and see if I can offer a suggestion.
HannahEd01
Hi Ollsbols, it is expected for the sound to be lower when using Bluetooth as you know, however, I found if the distance between the phone and the headphones is close it will make a huge difference.
