I purchased my sony ericsson w595 at local shop here in Lagos-Nigeria sometime last year. I'vent experience any problem until recently when i downloaded theme from zedge.net...my screen started showing random colours, somethings i wont be able to read anything from the screen. I try to restart my phone several times but the problem persist.. each day i discovered new problem, yesterday i discovered that the earpic is having problem too. when someone calls i wont be able to hear the person until i put it on speaker. Pls help, i love this phone, i dont wanna lose it. Thanks. Taitaiwo
****This same problem happens to my k850i and t303 last year when i download themes from this same site, i try to change the screen but the same problem persist..until someone told me that the problem wasnt from the screen.
Solved! Go to Solution.
Well obviously you shouldn't be using these themes.Delete them from your phone and run the SE update service via PC to update or re-install the phone's software and/or try phone repair via PC suite.Either way, the phone needs to be switched off.
Thanks for your responce. I try to repair my phone through PC suit but a dialog box appears, saying the phone repair has failed. i repeated this process more than 10times but still the same result. Plz what else should i do?
Thank you.
Perform a master reset on the phone.
