Problem: Standard Agenda App
Niet van toepassing
I'm having a problem with the standard agenda application on the SE x10. Quite often I use the agenda application, but suddenly it was completely empty. All the events seems to be erased from the agenda.
Does anyone know how to fix this problem?
suze
Leider
Just sorted mine out... Settings>Manage Applications then Menu button and select Filter and then All.  Find Calendar storage, clear data and do the same for Calendar.  Then exit out of that and go in to your Calendar app, either stock or installed and it should sync all your stuff back.  Hope it helps!
12 ANTWOORDEN 12
gwhispererz
Kampioen
Hi Meloentheman, first thing to check is whether you have selected the correct calendar to add and view. From Calendar app>MENU (left hard button)>My calendars, mark the appropriate calendar. Hope this helps.
Niet van toepassing
Thanks for the quick respons, but this is not the problem. All the settings seems to be correct and I did not alter them. All the data in the agenda were just gone.
The appointments in the Gmail agenda (online) however are not altered at all. Maybe a bug somewhere in the synchronization proces?
Uliwooly
go to Settings -> accounts & sync -> erase your google account and then try to re-add it again and that should solve your issue, it doesn't hurt to reboot your phone before you re-add the account
suze
Leider
I think there is a google calendar problem today because my X10, X8 and my husbands iPhone have all lost their Google calendar information altho it is still all present online and weirdly an appointment I added on my phone is no longer there but is online.  Hopefully they will sort it out soon cos its been driving me mad all day as I thought it was just me!
Niet van toepassing
I'm been having the same problem since yesterday.  I thought it was something I had done so, although annoying, its reasuring to know that its not just me!   I also noticed I get a message about an error when communicating with the server and unable to update widget.  I don't understand why the calendar and agenda are not working though.  I turned my sync off for the time being but my understanding is that data is still on the phone and so surely the calendar and agenda should still work?
suze
Leider
Found a temporary work around, open up your browser on your phone and access your google calendar from there.  You can add and delete etc appointments and all your existing stuff is on there.
suze
Leider
Niet van toepassing
Works for me! Thanks a lot! If someone else is not able to restore the data this way, you can always try to use the moxier agenda. It looks a lot like the standard app.
suze
Leider
Good to hear.  I didn't know how much I relied on my calendar until it wouldn't work... I was even thinking about going back to a paper diary!!!
