Camera disappeared
JPN
Bezoeker
Camera disappeared
I disabled from the camera settings the QuickButton, as camera goes on a quite easelly from the login screen of 4.3
The end result is that I cannor get camera on. The camera button doesn't work nor I cannot find the camera app 😞
I do get camera working with the additional app but via those cannot get into original settings.
I _reallty_ would not like to reinstall the whole FW, any hints how to get access to the standard camera app ???
JPN
Bezoeker
You are correct, the Camera application is there but with the of phone's set-up language (in my case 'Kamera'). That's why I couldn't find it amoung the others.
Thanks
7 ANTWOORDEN 7
profile.country.RO.title
_alexdon_
There should be an app called camera,the same like you would quick launch it.From there,enable quick launch.
alexdon
NKD
Bezoeker
go to settings > apps> all> the app u disabled will b there at the bottom of the list...find it tap it and then enable it Winking_Face so simple Winking_Face never panic Winking_Face its the world created by humans and we bettr know how to amend things Winking_Face
JPN
Bezoeker
Under the All
There is 'Xperia camera extension' and the 'Camera Common' & 'Camera extension'
The only option seems to disable i.e. they are available
Though I found the solution! Search Application-Camera ;  the Camera started and I was able to solve the problem. Still I have no Camera Icon available on the All Applications view but with camera button it starts???
_alexdon_
If you scroll down isn't it there?
alexdon
JPN
Bezoeker
Thanks
_alexdon_
Great.
alexdon
Hollaifyahearme
Bezoeker
This was the best solution and very easy too. Go to
Settings
Apps
'All' or there maybe a tab named 'Disabled'
Find the 'Camera' app and click 'Enable'.
Chances are you disabled the camera app when you were trying to make some space on your phone.
