'Xperia Companion' Xperia M4 Aqua Update Problem
SOLVED
Lost81
Initial error
An error occurred while preparing to update your device. No changes were made on your device.
Please try again later. If the problem persists, contact Sony support.
Error code: uestartnomoreports
L_2384
1 ACCEPTED SOLUTION
Accepted Solutions
CameronT
Champion
@kemal81,
So is it working now?
39 REPLIES 39
Uliwooly
@kemal81
could you test with a different cable and/or usb port?
Lost81
I did not try them all.
CameronT
Champion
Hi @kemal81,
Welcome to the community.
If Xperia companion is not working correctly there are a few steps that you can try to resolve this.
Try these methods one after the other. Verify after each method whether the problem was solved, before trying the next one.
  • Make sure that you have a working Internet access. Visit any website, for example, www.sonymobile.com, to verify that the computer can access the Internet. If that is a problem, please check cable, router or the Internet service provider etc.
  • Check your firewall and make sure that Sony Ericsson Update Engine and Xperia Companion are allowed to access the Internet. For instructions, refer to the user guide for the firewall.
  • Check your proxy settings. If you are trying to update your device when connected to a corporate network, you might be using a proxy. Contact your network administrator for further assistance.
  • Check that Java is up to date on your computer. https://java.com/en/download/
  • Restart the computer and try again.
Lost81
problem solved. Error code: ueınstallermd5check and Error code: uestartnomoreports
L_2384 error. Make sure the latest version of Java installed on your computer. xperia companion Windows 8 works as an administrator in compatibility mode. Establish a connection to open the program to download Android â„¢ 6.0 marshmallows.
CameronT
Champion
@kemal81,
ajitsarwade
How i am gonna get rid from "UELoginNetworkError  .nnn.. nnnnn_1210_0" this problem that i am facing during update several times??
Tags (1)
Lost81
yes no problem.
Lost81
Xperia Companion is running Windows 8 compatible.When the computer from Windows 8 compatibility mode Xperia Companion downlYou can update the tablet. I have not tried it in windows 7. I've tried Windows 10 did. In Windows 10 you say Xperia Companion program I right-click compatibility fix the problem. the problem
Tharena
Getting Error Error code: UEStartNoMorePortsL_2384
Found and followed all recommendations at : http://talk.sonymobile.com/t5/Xperia-M4-Aqua/Xperia-Companion-Xperia-M4-Aqua-Update-Problem/m-p/1145...
Internet Access is fine.
Firewall double checked and all necessary items are listed as accessing.
Switched the experia software to run in Windows 8 compatibility mode, and as Admin.
Not using a proxy, but have set the Experia software to automatically detect proxy settings itself.
Only have the most up to date version of Java installed.  (currently Version 8 Update 101 64b)
Restarted both after uninstalling ALL java versions and after installing most recent java version.
Still cannot update.  Also have fresh restarted the phone.
Any further recommendations?
