Solved! Go to Solution.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
Try settings-apps-all-sound enhancements,force stop and clear data.Restart.
This is strange.Try to unplug the headset while listening to music or while in a call.
How to backup?
Hi There
same issue here, no sound from speaker.
Is your problem solved yet?
thank you
Bruinenat
