Battery Drainage
SOLVED
Milan_
Battery Drainage
Hey Guys my batter is draining very fast in V1904... I have factorg resented 3 times still it's not working. I m from India I have not updated my phone still to 4.3... What should I do?? R
1 ACCEPTED SOLUTION
Accepted Solutions
Milan_
I had done charging for 4 hrs when battery was40% but then also no improvement is there instead its draining... I wanted to know that whether i should charge my phone 4-5 hours when battery completely drains and switches off ???? And should i charge it regularly or what ???? And also after using it in safe mode not much improvement is there ???? And also it really works or what after charging it till 5 hrs ??? Plz reply asap
11 REPLIES 11
alexrx
Enthusiast
Hi there,
Do you have Task Killer, Battery Booster, Antivirus or similiar apps?
If you have any of these apps, remove them all.
Boot your phone in Safe Mode and use it for a few hours and check if something will change for the better regarding your battery life.
Maybe some app/apps causing all of this?
How to boot your phone into safe mode
Also read this:
http://talk.sonymobile.com/t5/FAQ/Battery-time-and-enhancement-features/m-p/347874#U347874
Cheers.
alexrx
Enthusiast
.....Also you can try to update/re-install a phone software using Sony Update Service.
Sony Update Service
Milan_
I don't have any type ox battery savers or task killers in my phone nor any antivirus in my phone but still it's draining in normal stand by mode
alexrx
Enthusiast
In that case, boot your phone in Safe Mode and check whether there are any improvements.
sreenath
@Milan,
 when all idea is not working then do one thing wait for full battary drain... then full charge it in off mode...
Milan_
Still it's not working... In safe mode also battery is draining... In stand by mode also battery is draining when phone is idle also then also battery is draining
sreenath
@Milan,
  First u empty ur battary, wait for a 30 mins.... then charge it in off mode around 4 or 5 hours.........
Milan_
Milan_
Plz help me give some suggestions
