good gentlemen I want to get me out of a doubt, I'm in Colombia and want to activate the system location of my xperia satelitely to locate and follow the steps but did not appear myxperia settings which is the active application where the location as I can do that process.
Solved! Go to Solution.
Google has a similar service
https://www.google.com/android/devicemanager?u=0
Don't forget to give Kudos
This is an English only forum
@hectorpump wrote:good gentlemen I want to get me out of a doubt, I'm in Colombia and want to activate the system location of my xperia satelitely to locate and follow the steps but did not appear myxperia settings which is the active application where the location as I can do that process.
1. Is this feature available in your country?
Also, Your phone has to
1. be on
2. have a data plan or wifi on (Internet access)
for this to work.
Again, This is an English ONLY forum
it seems to be globally available
http://blogs.sonymobile.com/2013/07/04/my-xperia-now-rolling-globally/#more-9126
here is more info on how to use it
https://myxperia.sonymobile.com/
From a computer or another device, verify that your my Xperia account is working by using the Locate, Alert sound or Lock function. If nothing happens, find and tap Settings > Xperia > My Xperia > Enable necessary services on your device. Then verify that my Xperia is working.
the app MyXperia is available on firmware 15.0.A.2.17
