Hi
I just bought sony xperia L,
it's quite good, but I had several question while check it's internal memory. why does it have only 4gb internal memory? shouldn't it 8 gb internal memory(5.8 available)?
please answer this question,
thank you
Opgelost! Ga naar oplossing.
here is the info
http://www.sonymobile.com/global-en/products/phones/xperia-l/specifications/#tabs
** Memory comprises of approximate 1.2 GB firmware and 5.8 GB “Internal storage” for downloaded applications, music, pictures and films, and some application data.
here is the info
Could any one help understand how to check the internal memory space in Xperia L. When i check i do see only 4 GB space.
Where do i find the remaining 4 GB. please help with the navigation option.
Could any one help understand how to check the internal memory space in Xperia L. When i check i do see only 4 GB space.Where do i find the remaining 4 GB. please help with the navigation option.
with the provided link i didnt not find any useful info abt the space
Xperia L in factory condition (without third party apps installed) has around 5,5 GB of free space divided between phone memory (1.5 GB) and internal storage (4 GB).
The remaining memory isn't user accessible and is occupied by OS and recovery partition.
You can use an external microSD card to increase available space but here you can't install apps but only put your personal files.
Hello, i just bought a new Sony Xperia L , but i can't understand one thing, it says on specs that it has 8 GB of internal memory, i know that it never reaches 100% capacity that they say, for example , pendrive of 16 GB only has maybe 14GB ,something like that, but on my xperia it says "TOTAL Internal device memory 4.06 GB" , of 8.... what can i do to fix it? It has two memories, one from phone, another from internal, 8 GB means it's the two memories?
Sorry for ... noobish
Regards, Kuri619
Have you read the upper post by uliwooly?It has up to 8GB(from where the system files have 1.2).Both memories are in the 5.8.
