Satellite tuning guide for Sony TVs
140,855  Views
Our Sony TVs are equipped with a powerful integrated satellite tuner so you don’t have to connect an external set-top box and use a second remote commander.
Since there are several satellite dish configurations on the market this guide gives you an overview of how to set-up your TV and tune for your favourite satellite stations.
  1. Scene1.gifWhen you set up your TV for the  first time, you will be asked if you would like to tune for satellite channels during the set-up process – please confirm with ‘yes’. If you would like to tune for satellite stations later, open the satellite tuning menu by going to the settings menu, selecting ‘Channel setup’, ‘Digital setup’, ’Satellite Set-up’ and finally ‘Digital Satellite-Tuning’. Please confirm by choosing ‘Yes’.
  2. Screen07.jpgFirst, select your Antenna set-up. Depending on your installation, you will need to select ’Fixed Antenna or DiSEqC’ or ‘Single Cable Distribution’. The second option can often be found in large buildings with lots of apartments. If you select ‘Single Cable Distribution’ you will probably be asked for Band and Band Frequency information to get everything working correctly. Ask your landlord or the satellite technician about those details and enter them into your TV. If you have selected ‘Fixed Antenna or DiSEqC’ there’s nothing else to configure. Click next to go to the next step.
  3. Screen11.jpgNow you have to select whether you would like to use a satellite provider or not. If you use a satellite provider (e.g. Sky) select ‘Preferred Satellite’ and choose your operator. If you select this option the TV receives the channel list from the operator – so the order may be fixed. If you don’t use a satellite provider, select ’General Satellite’. With this option you can sort your channels individually after tuning (an option that is also available with a satellite provider).
  4. IScreen12.jpgf you don’t run the initial set-up you will see this screen. Select an option  to proceed.
  5. Screen13.jpgIn this step you will see the list of available satellites. How many and which satellites you see depends very much on your antenna configuration. If you have a basic set-up with only one dish and LNB your screen will probably look like this screenshot. You can start the tuning process now. If you’re an advanced user, read on for how to customize your scan.
  6. Now it’s time to configure the satellite tuning process. Select the satellite you would like to configure by using the up and down buttons on your remote. Confirm by pressing ‘Enter’.
         a. Screen15.jpgThe first option allows you to enable or
             disable a satellite – usually you
             keep it activated.
         b. The next option allows you to change
             the scan type:
              > ‘Full Scan’ performs a full scan of all
                 channels within this satellite.
              > ‘Network Scan’ performs a scan
                 within the transponders of a
                 network (NIT scan).
                 This scan type is much faster than a full scan but you have to enter a transponder from
                 which the TV can get its network information.
              > ‘Manual Scan’ allows you to search for transponders manually.
                 Please note that you can’t tune for single stations – usually you receive
                 4-8 stations per transponder.
         c. Next, choose to tune for paid and free channels or free channels only. If you don’t use a CI+
             module to encrypt paid channels, select ’Free Services’. The TV will not scan for all the paid channels.
         d. As digital satellites provide lots of different services like TV, radio and data services the next option lets
             you select the channel type the TV should scan for. Select the appropriate option.
         e. If you have selected ‘Network Scan’ or ‘Manual Scan’ you can select which satellite you search for
             stations. Select the correct satellite from the list. This option is not available when selecting ‘Full Scan’.
         f. The transponder details need to be added when performing a network scan.
         g. The last option is the LNB setting screen. If you have an unusual LNB type you might need to change the
             settings according to your LNB but often no changes will be needed. The settings for your LNB can
             be found in the LNB manual, which your landlord or the satellite dish technician can provide.
  7. After finishing the set-up of your satellites press the ‘Start’ button. The TV will now perform a satellite scan according to your settings.
When the scan is complete you will be directed to the channel sorting screen. Here, you can change the channel order by using the arrow buttons on your remote and remove unwanted channels by pressing ‘Enter’. Please remember that you might not be able to change the channel list if you have selected a satellite provider at the start.
We hope you find this guide useful. If you have any further questions please post them below in the comment section.
13 Comments
dusseldorf_blue
New
Hi Peter
I am trying to setup my new Sony OLED TV to also get the UK TV channels. I live in Germany
When doing a manual set up is it possible to enter a Transponder frequency range rather than a specific number for MHZ? On my old reciever I just searched on the 2nd LNB and got BBC, ITV, Channel 4 etc.  With the new TV it looks like I need to setup a satelite for each individual Transponder MHZ.
I hope my question makes sense!
Cheers
Matthew
Hi Matthew,
I would recommend to do an automatic channel search instead of lookinfg for channels manually.
Thus you can do a full scan and remove unwanted programs later.
Cheers
Peter
KOOGA1
Good morning Peter
just a quick question - i recently purchased sont tv model kd49xe8396
i have the tv connected to my satellite dish and i have astra 19, 23, 28 and hotbird 13 all tuned in and working fine
I wish to add a new tv channel without doing a full rescan so can i manually add a transponder and do a scan?
thank you
MrsCGT33
We have tuned our new TV according to the above guide; however, sometimes the speech is out of sync with the picture - is there a way of rectifying this. Also, when we tried to use catch up services, and set that up it said that we couldn’t use satellite broadcasts - what does this mean as we want to use YouView to watch programmers on Iplayer etc (which I thought came via the internet so wouldn’t impact on satellite channels). We don’t have a digital aerial, only a satellite dish.
rrjarvis
New
I have just purchased a Sony XF9005 tv and have set up the satellite connections all has gone well but the tv Guid does not seem to provide any details of what is on just the channel, is there somthing I have done wrong or does it just take hours for it to populate?
Any one else have this issue?
MrsCGT33
We had exactly the same issue - unfortunately it transpires that the TV guide only works through an aerial connection as its YouView (ie linked to free view rather than FreeSat!!). Very very annoying as it isn’t AT ALL clear when you buy the TV that you can’t use the TV guide for FreeSat. We ended up getting a new TV aerial so that we could actually use all the fancy interactive services. (We have also linked up our old Humax FreeSat box to the satellite dish so we have the best of both).
Hope this helps
Vanilla_
Contributor
Hi rrjarvis,
I agree with (MrsCGT33). As far as i know, Sony TVs provide full functionality for Digital channels guide only. Satellite guide  functions are not fully available.
Vanilla_
omer-Karamanoglu.1
New
i have completed the satellite tuning saccessfull on my KD49XF9005 TV  but i did not get a HD channels ,
kevin-harman
I have just bought a KD-49XF8796 and it has the double satellite inputs and I have connected it to my dish.
When I go in to the settings to tune the channels the satellite tuning guide is greyed out.
Is there anything that can be done???
mark1music
I have a KDL-55W905A and if you follow the guide above it only finds one of the 28 degree astra satellites.  I just can't figure out what to input for the details for Satellite 2,3, and 4.  Frequencies? Polarisation?  I don't understand why the TV can't just scan and find out what is there. (I.e. it finds the Sky channels (which are obviously encrypted) but all the FTA stuff like BBC, ITV, etc don't show up after a search.
Perlies
I don’t have that option under settings.  My former tv was a Samsung and it works with a cable direct from our satellite dish but the new Sony doesn’t.
LightFoot
Specialist
Hi @Perlies   Please post a forum question if you are expecting an answer. Remember to include the full model number of your TV. It will start with KD.
https://community.sony.co.uk/t5/android-tv/bd-p/Android_TV
erolemin
I have connected a dish to my Sony KD-49XD8088 it has a main and a sub..
i have gone to settings, channel setup - digital setup but the satellite setup setting is greyed out? The dish is ok as i have just stopped watching sky on it..
Thank you
