Hi Harry,
Sorry you're still having difficulties.
Quinnicus has kindly created a new post here which might help you:
[AV Receivers] Pass Through - Potential Solutions
There's some Sony TV settings which might be of interest, it's certainly worth checking if you haven't already seen the post.
My HDMI Passthrough problem gas gone away. Bought new TV - Sony Bravia 42
That's cheating!!
Still, I'm happy you've finally found your solution, albeit a rather expensice one.
Ye, expensive, but so far, seems worth it.
Bought a Sony Bravia KDL-42W705B, which handles the HDMI control and works well with the amp and my other equipment. Very happy with the picture quality, despite the guy in Richer Sounds trying to talk me out of a Sony!
Hi Guys,
I got a refurbished DN1040 today, had this problem for a while. Happened to fix it whilst reading this thread.
I turned "audio out" to "AMP + TV".
This worked imediately, I now have HDMI pass through. I hope it works for everyone else.
Sorry should have included this:
Panasonic Viera
DN1040, connected to a PC via HDMI, QNAP 251 Turbo.
I had tried multiple leads, settings and hdmi ports on the tv and avr before trying the above idea.
If this works for you please do leave a message.
Hi there, thanks for sharing your recent success!
I would like to add however that although this might indeed work for some people it can also cause an unwanted side effect for owners of 2 channel stereo TV's / Recorders like myself.
I discovered that with the Audio Out set to 'AMP+TV' I could only get PCM playback form either my TV or Panasonic DVD / HDD Recorder. However, setting it to 'AMP' only allowed me to enjoy Dolby Digital audio output from either device.
Maybe you will / have noticed the same thing?
STR DN840 also has the same HDMI pass thru function problem. Found out by Costco Tech support that it is not compatible with new (2019) Samsung TV's.
If I was you, I'd stick with the Yamaha. You just have to find the right settings for your preference. There're much more surround sound settings available on the Yamaha than there is on the Sony. Sony has an intrinsic problem with the pass-thru's and they need to correct it. You're wasting your time in obtaining another Sony replacement.
