netflix on N7100w
mijense85
netflix on N7100w
I dont have the netflix channel as an option on my new bluray system allthough it should be compatible. ?
Can someone please help me?
This was one of the reasons ni choose this system
Thanks in advance.
- Michael
6 REPLIES 6
mijense85
Bdv-n7100w of course
Anonymous
Not applicable
Hi there
Yes, Netflix should be on there.  Have you connected the bluray player to your home network? And can you see things like BBC iPlayer?
Basically I am trying to establish where you are with things?
Cheers
mijense85
Thanks for the quick reply. I am based in Denmark where there should be netflix as well. But it only gives ne things like lovefilm.
Thx a lot
Anonymous
Not applicable
Gotcha - Yes Denmark has Netflix :slight_smile:
Have you tried performing a Network update?
If so, try the following
  1. Reboot your ISP's router
  2. Perform a Factory Reset of the N7100
  3. Redo all settings again (im afraid)
Hope that helps.
EDIT: Just noticed - On the remote control, there is a Netflix Button - What happens when you press it?
mijense85
Thx a lot :slight_smile:
Will try it out tomorrow...
Anonymous
Not applicable
No probs - Not sure if I posted in time - What happens when you press the Netflix button on the remote control.
