Erroneous channel recording error SOLUTION
Mr_Onion
I and others have repeatedly reported that the PVR timer won't record due to the channel being duplicated up in the 800's
If you delete the extra channel, then you can record until it reappears, then you get the same problem again.
If this sounds like your problem, try this. You need to 'lock' the duplicate channel.
System Menu>Initial Setup>Digital Tuner>Channel Options>set or enter PIN>select the rogue channel>select Lock with the navigate keys>exit
I have had this set this way for over a week now, and everything has recorded perfectly. Sounds like famous last words doesn't it?
0 REPLIES 0
