I was making a recording using my Sony HXD870 when the machine was unplugged from the mains. It now won't work. How do I fix it?
Solved! Go to Solution.
Above you can find what E02 (and other errors on HDD) means. To have a more detailed analisys you should enter service mode, for which you need a specific remote.
In any case, when it shows E02 you already have lost all the data...so you can format it !
I had the same problem last night and this morning I found it would only go to DVD mode and showed a E 02 message. After a lot cursing I found that if you go into system -> disc setup -> hdd format and reformat the hdd it seems to work. BUT it does wipe out the title list much to my annoyance as I had a number of programmes stored I wanted to keep 😞 I have tried recording a few bits and pieces this morning and we seem to be back on track. Hope this helps.
