Solved! Go to Solution.
@Sipiimi wrote:
Back to the question. Does Dn1040 can play picture or/and movies?
Hi there
The STR-DN1040 cannot play photos or movies via DLNA Streaming or USB playback. Where did you get this brochure that says it does? If you look at the manual as well as the product specifications, it only mentions music. Therefore other types of media is not supported.
You also mentioned:
"The tv signal does not goes through when the DN1040 is turned off. It worked before well."
But you might want to ensure that Pass-through is ON or AUTO - Page 94 of the Manual : HERE
Hope that helps
Hi there
You also mentioned:
Hope that helps
