Adding surround/centre speakers to a Sony KDL EX713 TV using an AV receiver
timodell
Is it possible to use my TV'a main speakers while decoding a centre/surround channel using an Av receiver? Being an old set in the corner of he room, I don't want to use an external pair of main speakers if possible.
1 REPLY 1
Anonymous
Not applicable
Hi there
When you add an external audio system, like an AV reciever, you select either TV speakers or Audio System in the sound settings.  Unfortunately not both at the same time.
http://pdf.crse.com/manuals/iManuals/egb/3a-03/speakermenu.html
Cheers
