When i press record the CD wont Record the same with Vinyl on Turntable Iam using CD-RW Could someone come on Video chat tommorrow evening and go through with me On Facebook [edited by moderator to remove personal details] cheers
Opgelost! Ga naar oplossing.
Hi Dave,
Welcome to the Community.
It's best to contact Sony Support about this.
Thanks,
Pascale
Have you got the correct cables connected and have you chosen analog, optical or digital as the source, I know this is an old problem but I will help for future users of this item as it’s popular on eBay.
When I imput songs on Vinyl ,How do I put the Stylus On the Record And Record At The Same Time? So I Can Catch the song Before Recording the Song? Once I stop the Vinyl at the end of the Song do i stop it, then enter the Song then Finalise? Or can the Songs Be Put on Automatically On Vinyl? Save Imputting songs On the Labelling The Songs? Why Do You put the songs on Manually when it can be Done Automaticcally?
This is Sony Community. Just clicked The Message it says Not Private It Wont let me on I have registered on This Community Site.
Put cd on record with pause button ready to be pressed use deck b making sure input is set to analogue, now when cd recorder displays new track in display put stylus on record and press pause using your eyes and judgment to when the track starts playing, pressing record in between tracks at the gap will split the recording into tracks like a retail cd then ones after last track press stop you’ll see PMA has finished writing press finalise and pause on deck b wait the 64 secs now the cd will work on any drive I use a pc to label tracks like on EAC or iTunes and a lot of the time the metadata loads automatically. Use an Audio CD-RW and once ripped to a pc unfinalise cd and erase to use again or it gets expensive quick. Audio CD-R can’t be erased. You can’t alter text on cd after finalising but CD-RW you can finalise and unfinalise as much as you like also, delete tracks remember if you delete say track 4 then 4 and every track after will get erased.
Which is the Pause Button?
