Xperia 10 cannot connect to mobile network
matinzk
New
I have just bought an Xperia 10. Put my sim card in it and went through all the initial setup. However it cannot connect to the Three network.
The sim card is fine. I have tried it in a couple other phones.
I have also tried other sim cards in the Xperia 10 and no luck.
I have done the factory reset a few times with no luck. I have also gone through turning off the data roaming, changing network type and also tried to connect to the network manually and still nothing.
Is there anything else I should try before returning it for another one?
Thank you.
1 REPLY 1
Anonymous
Not applicable
Hi there,
It might be best if you contact Xperia support here.
Let us know hoe you get on.
Best wishes,
M
