i want to order the WF-1000XM3 but i was just wandering if i connect them to one device and set up everything on the app on that device i.e. noise cancelling and then switch devices will it stay the same or do i have to set it up again?
thanx
Hi diddy11,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Hi Diddy,
The settings are saved even if you later connect the headphones to a device that doesn't support the companion app
Win_88
