Do all notification light turn on while charging?
ROZWIĄZANE
xperiaEman
Początkujący
all notification light greeen red pink yellow light up while charging.....repaired through pc companion once....still same  ......after reaching 90% it goes green only.....any fix....or is this normal?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
xperiaEman
Początkujący
instead of yellow all colours light up.....did pcc repair once
Wyświetl rozwiązanie w oryginalnym poście
9 ODPOW. 9
Can you please elaborate, I'm not really following what you are explaining.
When charging the notification light should light red when you have low battery, yellow when you have medim battery and then green when you are around 90%.
xperiaEman
Początkujący
Oooooo.... Instead of yellow all lights turn on... red light when battery low and green when battery above 90 works fine..... Instead of yellow ,all lights turn on..... On top view I can see green and yellow from an angle I can see pink red.etc...
xperiaEman
Początkujący
I'll get a picture... Later...now charge is full...:-o
xperiaEman
Początkujący
xperiaEman
Początkujący
xperiaEman
Początkujący
It's my phones problem... After update same issue
osk
Początkujący
mine has the same issue all lights red yellow green !!!  when u see at different angles all are there!
This seems to be the case. I will pass this feedback on internally.
xperiaEman
Początkujący
Thanks
