I have purchased a Sony DSC-H300, I cannot find a "Sunset" setting. What is it best to set the camera to?
Opgelost! Ga naar oplossing.
Hi Gramps1,
welcome to the Sony User Community Forum..
Although the DSC-H300 has several scene selections it doesn't have an actual sunset mode, I would suggest using Superior Auto mode as this should enable your camera to pick what it thinks are the best settings for the scene..
Once you get used to using your camera I would encourage you to try taking some photos using some of the other P, S or A more manual settings..
Hi Gramps1,
