I realize that no two TV’s are the same, so someone else’s calibration might not be right for me. But since have no idea what I am doing could someone share their picture setting with me so I have somewhere to start.
I did this on my previous TV and it worked fine. Even adjusted the individual colors and everything.
If you have good settings for gaming that would be great as well.
Hi there
I dont have this TV, so my settings will be useless to you. As you note that there can be slight differences between TVs, you should also be aware of differences between environmental factors, such as the brightness of your room compared with someone elses. Also, individual tastes too.
My advice is to create a spreadsheet with the default settings, then slightly change them over time, making note in the spreadsheet, so you can revert back to previous settings if you dont like it. Will also help if/when it comes to factory resetting the TV at a later stage.
Lastly, have a read of this FAQ:
Cheers
